HMS_Beagle's avatar
HMS_Beagle
Explorer II
Jan 19, 2016
Bedliners revisited
I thinking of re-trucking, and therefore revisiting the bedliner question. On my old truck, I had a polyethylene liner, and had some problems with the camper shifting. Some put this down to the bedliner. So I paid the $$ for LineX. There was no difference, camper still shifted until I made some guide rails to keep it in place.
On the new truck I am thinking of going back to a PE liner. The Pros seem to be: protects the bed against dents, protects the paint against scratches, less costly than Linex, looks better. Negatives: have to cut holes to put in trailer connectors, can trap rain if you park downhill. On the LineX, the Pros seem to be: don't have to reach through holes for connectors/holddowns. The Cons: Costs more, doesn't protect against dents, makes everything difficult to disassemble, fades quickly and unevenly in the sun.
One of the objections to a PE liner is that it eats the paint. This is true if you put it in without a liner liner. With a liner liner, the paint will not get eaten or scratched. When I pulled it from my 16 year old truck to do the LineX, the paint was showroom new.
Maybe there are benefits to the LineX I have not thought of or considered? A lot of people seem to like it but I'm not seeing it right now.
  • I have always used a bed mat, just to save whatever was under it from the screw heads that festoon the bottom of a Bigfoot. When I had the PE bedliner I had a plywood platform on top cut so it locked onto the bedliner, then the mat on top of that. With the LineX, I have a 3/4 plywood layer with the rails on it to keep the camper centered, then the mat on top. I thought maybe the PE bedliner which is kind of corrugated might be compressing a bit on the corners allowing the camper to lean and shift. But there was no difference with the LineX.
    I've seen that Dualliner before. Seems like it would let dirt under it through the joints, then you might have paint wear? Maybe the ultimate answer is LineX with the dualliner on top.
  • I use a heavy duty rubber bed mat on top of a spray in liner and have never noticed the camper shifting. Since I bought my truck used I don't know the name brand of the liner... but because I've had Rhino liners in other trucks I'm sure it's not a Rhino, from the looks it could be Line-X or similar.
    In any case I think a lot of truck camper owners use a bed mat.
  • What about spray-on bedliners?
    They suppose to be the toughest thing on the Earth.
    On new truck it is $500 option, but I had F250 that PO sprayed over the fenders with bedliner into triangle shape.
    I was so-so on looks, but loved practicality.
    Ford also supply bedmats for about $150, but can't find users with opinions about them.
  • Look at these plastic sides rubber bottom. I have never used or seen these other than TV and online.
    http://www.dualliner.com/
  • With the PE bedliner, you have two modes of camper movement: camper can slide on the bedliner, and bedliner can move within the bed. LineX eliminates the second mode.
