subdbf572's avatar
subdbf572
Bent frame on new Forest River Wildcat TT
We Purchased a new Forest River Wildcat 26ft TT in July of 2013. This July I dropped the belly pan to install some 12V power outlets. When I did I found that most of the electrical wires were not protected from chaffing on the frame as well as the water lines, but my biggest surprise was when I got near the axle and found that a frame cross member was bent. I believe that Forest River should buy this back. Where was their quality control? Please let me know your thoughts. If any one would like to see a picture of the cross member let me know.
  • I had a car that went through 3 set of front bushings in 3 months..(under warranty of course) But was concerned it was happening at all. Upon putting it up on a rack my attorneys mechanic determined it was going down the road at an angle. The camber toe couldn't be adjusted within specs. Factory issue. After a year of going back to the shop etc etc.. I found a solution, same dealer was more than happy to take it off my hands, if I purchased another vehicle. As mentioned it might be easier to just replace the bent cross member if doable an practical.
  • You bought it this past July and did work the same month but you are addressing 2 months later? Could have been damaged at factory, during transportation from factory to dealer, at the dealers lot or while you owned it. There is going to be a bunch of finger pointing. The burden of proof is on you. You might find just replacing the part easier than fighting.
    Good luck.
