gbsb's avatar
gbsb
bent jacks
New problem. I was unloading the camper off the truck today and had some blocks under the jacks for extra lift and the right front jack slipped of the black and the camper tilted to the right bending both front jack mounting brackets. what is the best way to straighten the jacks. If not for bad luck I would not have any at all. Not really bad luck I should have been looking closer.
  • A local fabrication/welding shop should be able to help you. Maybe even a body shop.
    It will probably take some heat and force to do it.
