valhalla360
Mar 18, 2018Navigator
AMG would be a waste of money. They are primarily designed to not lose fluid if tilted on their side or upside down.
Assuming you just need them to start the engine, any cheap battery of sufficient CCA will be fine.
If your current batteries are always dead, check for stray current before replacing the batteries. The best batteries in the world will still go dead if you let them sit for a couple weeks with a 5-10amp constant draw. Did you add some aftermarket device that doesn't shut down when you pull the key?
