Most builders list the absolute lightest weight without ANY options. Capris weight didn't include the cabover as I recall. When we had our half ton I looked into Capri as the initial weights posted were in the ballpark. But then I started adding the necessary equipment and not only the weight became a problem but the associated cost as well. Just be sure to do any research with care and diligence. The only realistic hard sided option I came up with (weight wise) was the Eureka but unfortunately, they are no longer an option.
