Aimcat wrote:
Also we will be pulling with a Dodge Ram hemi 4wd I think max tow is 7900
TomG2 wrote:
Jayco 195BR has the usual "Short queen" bed. Lightweight, low cost, two year warranty, lots of dealers.
We've towed a 195RB the last two seasons with our RAM 1500 CC 5.7L and it does a great job. Have about 10k miles on the combo so far. I will point out that for the 2017 model year Jayco increased the black/grey tank capacity to 20g each. It is a much-needed improvement although the smaller capacity tanks of our 2015 model have never been an issue for how we use the trailer. If you do look at the 195RB I would step up to the Baja edition. Better clearance and tires and an increase of 250lbs on the GVWR helps with the cargo capacity.
You could also check out the Star Craft RV Autumn Ridge Mini 18QB. Star Craft is a subsidiary of Jayco so you get the same 2 year warranty and the floor plans are pretty much the same as their Jayco counterparts. On the Star Craft the "Extreme package" is the same as the Baja edition on the Jayco.
