jaycocreek
Oct 13, 2020Explorer II
Kayteg1 wrote:
Sounds like you never had a chance to compare?
Generators on trailers are mounted low to the ground and can have long exhaust pipes that will direct exhaust long way from door and windows.
Such setup is not possible on TC.
Usually on a TC the gen set is at the rear of the TC away from seating and windows..There are exceptions..
On Class C motorhomes,I had one Onan 4000 right under the dinette window with the exhaust even with the skin of the unit..It was almost centered from front to rear..On another Class C it was under the rear door with the exhaust aimed to the rear under the bathroom..
You are referring to people mounting a Honda(example) in a sealed generator compartment of a TC with the exhaust piped out and away from the TC used as a factory install would be...Some have converted to propane on there honda just for that...
I see nothing at all wrong with that,you do so I guess we agree to disagree..It is no different than putting your portable gen set under the TC to keep it out of the rain in IMHO..Wind changes make any positioning of a gen set problematic and where common sense says..Move it..LOL
