Yosemite Sam1 wrote:
GrandpaKip wrote:
This is not a good idea for most trailers. They are not designed to be lifted from the ends. Those are not jacks, they are stabilizers. Even though my BAL stabilizers are rated for 6k pounds each, I certainly wouldn’t try to raise the tires with them. Real danger of doing the frame serious harm.
So why did the manufacturers themselves locate their stabilizers at both ends (mine does and motorized).
It's not meant to lift the tires as it also serves as support to the trailer.
Can the jacks do more harm on the farm than the pounding it is getting once you travel on those weather-beaten national park roads?:B
Stabilizers are meant to , well, stabilize.
The idea is to stop downward movement, not suspend in mid air.
Takes much less beefy material to just stop downward flex movement than it does for lifting and supporting dead weight.
So most items sold or marketed as "stabilizers" simply do not have heavy enough materials to safely lift and fully support 2K lbs- 3K lbs at each corner.
As far as bending the frame, the longer the frame the more bend or sag there will be when unsupported in the middle. If you are using the stabilizers correctly there is a considerable amount of weight still resting on the axles, so the axles are contributing to keeping the frame from over flexing.
The main take away is to reduce movement you need something solid under the frame. The longer the trailer is the chances of needing to add an additional support in between the stabilizers will increase.
Adding a jack of some sort halfway between the stabilizers will reduce the unsupported span distance and will restrict or reduce downward movement of the axle suspension.
This is a similar problem that you may find in a home where the floor joists/beams may be slightly undersized or span between is greater than recommended. Often in many cases with homes you can sister up and add extra material to joists or beams to reduce the floor flex.. Or if in the case of a basement or crawl space you can add in an extra support column to reduce the unsupported span.
Some bounce movement is good as it cushions your feet and legs when walking but sometimes it may be too much or some folks may not get used to it or are more sensitive to the movement and bounce.
You only need to stop the downward movement from the suspension not lift the tires off the ground.
