For a fiver with a GVWR under about 17k a SRW 1 ton works excellent. A long box is a little nicer with the fiver hooked up and a short box is a little nicer when running around empty with the truck. For a fiver with a GVWR over 17k a dually is a little nicer. The Solitude 378 is right about where you could go either way. If you buy a triple axle fiver you might be able to go a little heavier before needing duals. My fiver weighs very close to 17k with my motorcycle on the back bumper and my choice for a truck is a 1ton 4x4 diesel crew cab short box.
