devildog1971's avatar
devildog1971
Explorer II
Oct 11, 2019
Best way to install extra propane
I saw a 2017 Northern Lite with a big L P bottle somehow attached to the rear bumper. Cummins gave me paperwork on how long the generator would run usually half power with two 5 gallon standard L P bottles just about eight hours in the fall winter and spring these numbers might be sufficient. To run the fridge hot water and some heat. But summer camping that is inadequate.
Would it be best to try and mount two more of the 5 gallon tanks to the bumper and swap them out as needed, or something bigger permanently running the line into the regulator. Our second truck camper was a 1998 Real Lite. It had two 7and 1/2 gallon L P tanks that slide in sideways and we never ran out but that is a little over three of the smaller ones filled at 80%
With cooler weather coming on I have some time, we enjoy mostly dispersed camping so I do need to get a plan together
With the large bumper on the Northern Lite I could make mounts for two 5 gallon tanks to swap them out or maybe a larger one that is constructed to lay sideways. I am going to check out factory type mounts for the bumper, if that is not successful it will be time to put the fabricating hat on. I f you have suggestions please let me know. We very much want to make a trip to Alaska so extra propane would be a big help not knowing the distance between L P stations
