myredracer
Apr 23, 2019Explorer II
Check your fridge make/model and look up the manual online or contact the manufacturer for max. out of level degrees. Don't know what fridge you have but our Norcold is designed to operate up to 6 degrees out of level front to back and 3 degrees side to side. Older fridges can't be out of level as much.
For a fridge oriented against a side wall, 6 degrees is quite a bit and an 8' wide TT one side would be 10" lower on one side. A 30' long trailer with fridge in same orientation would be 18" lower at one end.
An out of level trailer can be a challenge to sleep in!
