Old-Biscuit
Apr 23, 2019Explorer III
If fridge is on roadside...then absorber tubes run front to back with downward slope
If fridge is on curbside ...then absorber tubes run back to front with downward slope
Best to be 'comfortably level'...meaning you can walk up/down RV, lay in bed, cook etc comfortably
20 minutes off level operation is all the time needed to being the death spiral....gravity flow of coolant gets disrupted, overheating of coolant occurs, crystals are formed & plate out on inside of tubing, which leads to more obstruction/more overheating/more crystals/more plating out------accumulative and permanent damage until DEATH!
