bmanning
Nov 04, 2013Explorer
Forgive me if you're already aware of this, but going to a larger tire is effectively the same as changing your gear ratio in a negative way.
Then again, I assume your Ram 1-ton has the Cummins so unless you're towing REALLY heavy you probably won't even notice the difference, especially since you're not upsizing to a 37" or something nutty.
Your sig references "looking for a better truck this fall"...I assume since you're tire shopping you've changed your mind on that? What issues have you had with your 08 Ram?
