GypsyJason's avatar
GypsyJason
Big Problem with Lance 1161 Slide (new thread)
Hi there,
So there's another topic for pretty much the same issue, but since its about 8 years old it was closed, or I would be posting there.
I purchased a Lance 1161, that appeared to have a repair under the slide out (3" aluminum angle under the slide out frame). I purchased the camper for what I thought was a good deal. Well, that fix turned out to be not so great, 6 months later - it started to twist sideways not allowing the slide to fully close; then it started sagging.
I bought it from a private party who said he knew nothing of the repair.
Next step; I shopped around (was in Northern CA at the time), and nobody really wanted to fix it. I went by Lance in Lancaster, and they quoted me $5-$7k, almost the price of the camper before I added some mods and a $2k solar system, ugh.
I finally found a place in Sacramento that said this kind of repair was right up their alley and they scheduled me an appt for October of 2017 (this was around August). Took it in, said I wanted ALL the dry rot repaired (wing replacement) and that crappy angle replaced and fixed to the corners and re-covered so the slide would go all the way in. I also ordered them the slide modification that Lance sells.
3-weeks later after a few calls they said come get her. I went to pick her up and initially she looked great. Angle was gone, the camper was on its jacks and the slide opened and closed. On closer inpspection, they had not replaced the rotten wood under the wing. They also hadn't done the seals like I had asked, so before paying them they put 3 guys on the job to reseal. After that, I said I was still upset about the dry rot not being repaired. They asked if I wanted to leave it. NO WAY - So I loaded it on to my truck (after writing the check) and as soon as she touched down, sag was bag and the top of the slide popped open a couple inches...... Ughhh, an argument ensued and I ended up paying for their parts and there is botched repair number two.
That lasted about 6 months and it started to separate at the corner and the sag got worse. I have not been able to find any reputable outfit that can repair my camper so I'm looking for advice. There's several members that effected their own repairs, so I'm wondering is that really the only option to fix it correctly....? Can anyone recommend a place to repair it...? I'm certainly willing to drive it wherever she needs to go to be fixed. I really love this camper, made her my own and if I can fix the slide out frame / wing, I'll keep her forever.
Anyway, just finished a trip through Death Valley, I knew it would probably be her last adventure until the repair, so I'm ready. Just looking for some advice, paid help or referrals to a reputable repair place. Here's the latest pics, its getting pretty bad. So sad to look at these.
Please post or PM - and Happy Thanksgiving....!
Gypsy Jason
Front to rear view:
Drivers side view (slide):
  • Welcome to the the club.
    It is infamous Lance design, where you have horizontal steel chanel under the slide and then you have vertical steel behind the jacks, but they are about 2" short to meet, so the critical stress point has some stapled toothpicks to handle the load.
    I pulled slide out and put bigger steel chanel inside, overlap it with corner steel and bolted together. Had to pull some siding in bathroom area to get new steel under the sink, where Lance has structural junction.
    Than I add additional aluminium angle outside the frame for extra support, screw everything together every few inches and reglue the siding.
    Lot of pictures how the frame is build on Lance forum, where Captain made great pictorial from fellow member camper rebuild.
  • work2much - Yes the turnbuckle has a spring inside. My F450 is a cab and chassis, so I had to have everything fabricated for it including the tie downs. Nothing is available for it on the aftermarket. If I had only known that before I bought it. Re turnbuckles - Yes - They are at a steep angle, and I hadn't thought about that being a problem but this issue is definitely not because of that. There's been soft spots under that wing since I had it on my F350 for about 6-months, and the botched repairs have just made it worse. I have been keeping that one turnbuckle on the effected side, more slacked than usual and that babying seems to have kept it at bay for awhile. Its just this last trip was a little bouncy.
    downtheroad - that is within my range so I'll check them out. I was hoping to hear from other members who own this camper. I did thoroughly read the other thread about their repairs back in 08 and 06, so I will probably reach out directly to see how its going.
    ticki2 - I will check with them ad see, maybe its the same place downtheroad referred me to. I could definitely make the trip up there. I'm good with tools and such, but I lack the experience to effect a repair like this myself, so logically it would make more sense for me to just go back to work and get the money and pay someone else to do it right, but having been burned makes me want to make sure its done right and be part of that process.
    Ahhh, the life. When its great its great....when there's a big issue, its not so great, but its still a lot of fun..!
    Thank you everyone for feedback so far. I appreciate it...!
  • I definitely wouldn't haul it again until it is fixed. I would pull the belly pan off to have a good look at what needs to be done. The tie down looks to be at a steep angle. Is it attached to happijack bed mount? Is there a stress relief component in the tie down? If not you may be putting too much stress on the camper. If there was a previous issue this could be adding insult to injury.
  • Members Sleepy and Boatycall had their 1161 completely rebuild at an outfit in WA , both very pleased . Try contacting them for more info . IIRC it was about a year ago .
  • Do you have springs on your front turnbuckles? It almost looks like they are tearing your camper apart.
  • Doesn’t look good.im not sure what the factory will do. Need a whole ne wall.
  • If you want it fixed right, take it to Lance factory.
  • Ouch, hopefully one of the people who've repaired theirs will respond soon.
