agesilaus wrote:
I've never heard of a vehicle rental place that didn't forbid towing of any sort. If you find one that rents trucks, the trucks won't come with a tow package.
As for truck stowage: APT above is correct get a tonneau cover or a topper.
From the U-Haul Website.
U-Haul is home of the $19.95 pickup truck rental! (Extended miles, week long and month long rental rates also available) Rent a pickup truck for any of your personal or business needs, our pickup trucks are also great for local deliveries. Pickup truck rentals are commonly used for home improvement projects, self-deliveries and other small loads. Rent a U-Haul pickup truck starting at just 19.95! (Extended miles, week and month long rates also available)
U-Haul pickup truck rentals are perfect for:
Home improvement
Deliveries
Small loads
Tow your boat
Trailers
Most U-Haul trucks are fully equipped to tow a trailer. If you plan to tow a U-Haul trailer, you will be provided with the appropriate equipment and instructions. Read the U-Haul Trailer User Instructions thoroughly. Follow the instructions on how to properly load and operate your truck/trailer combination.
If you plan to tow your own trailer, check with a U-Haul representative to determine the maximum trailer weight you can tow. Make sure your trailer is properly loaded, that the coupler and safety chains are attached and that the trailer lights are working properly. See your trailer owner's manual for more information.
