Photomike
Apr 22, 2015Explorer III
Mine on my NL was really sticky (still have scars to prove it). One day after dumping and flushing the tank I thought that I would try something. I took a can of WD40 and sprayed up into the pipe to soak the flapper then I opened it and did it again. I also lubricated the little slide attached to the handle. Almost pulled it off when I was done as I went to yank it open and it worked perfectly, scared me as it was so smooth. Has lasted a couple years since I did that and still works good.
I have heard from someone that toilet paper can get jammed in there. One person said to look up there with a flashlight to see if anything is jammed. Fortunately I did not have to stick my head up there :E
