bigfootford
Apr 23, 2015Nomad III
woodmn08 wrote:
sorry about the model ,mine is the 30C1002
and i am hoping there is no water tank to remove
I did a search for you and the only thing I could find was this thread and post from 54suds. He just says his is a 99 3000. On his he had to remove the plate and the valves were easily accessible.
https://forums.woodalls.com/index.cfm/fuseaction/thread/tid/28052054/gotomsg/28052342.cfm#28052342
The 2500 valves are easily removed and repaired. I too had to cut the gray water tubing from the tank to the valve to get the assembly out. I then used a rubber plumbing coupler and reducer to match sizes... Not a big deal.
Jim
44,070 PostsLatest Activity: Aug 05, 2026
