bigfootford
Apr 28, 2015Nomad III
Well yours is definitely not like the 2500's.
I did cut the gray water pipe from the tank to the valve assembly. I inserted a rubber coupler so there is no stress and allows the valve to move a bit as I slid it into place. That helped the clearance problem.
My black and gray valve assembly is a integral piece. I can unto the black valve from the assembly, remove the clamp on the gray and the whole assembly comes out.
Not sure if this can apply to your installation.
Jim
Jim
