Photomike
Oct 19, 2022Explorer III
You already had some good advice for getting the colors matched. A professional paint shop will be a good choice and a fiberglass shop even better.
A word of warning. You will find that the camper is not all the same color. Fiberglass does not age / discolor at the same rate. On my NL I polled some window trim and on one side it was a little whiter under the trim than the fiberglass around it and on the other a lot whiter. Also I have seen a lot of fiberglass campers repainted and the ones that I saw LOOKED HORRIBLE!!! The paint was not as glossy and it peeled.
I have been told to do it correctly you need to sand, paint and top coat. Again I would hit up someone that deals with fiberglass to verify before you start.
44,059 PostsLatest Activity: Mar 18, 2026
