Gaetan sent me a couple of pictures and has more to send me...
Here they are:
My initial thoughts are that the rim around the bottom of the BigFoot is all the camper is supported on when sitting on plywood in the bed of the truck, at least that is what I use. The plywood has impression of the bottom inspection plate screws and only the perimeter of the camper leaves an impression. That and along with the center support for the floor and tank area. A bit of damage in one spot that I see is a non worry. The Gelcoat is cracked and some removed but the question is, is the Fiberglass around the cracks in the gelcoat mushy.
Even if it was I would probably not be concerned... Gaetan can provide that information and maybe some more pictures.
Jim
