Bedlam
Jul 19, 2014Moderator
I'm currently looking at 550's with GVWR's over 19k lbs. 450's are about 16k lbs which are closer to 350's. The 450 will typically have a better GCWR than a 350 even though the GVWR may be close.
BTW: There are two flavors of the 350 and 450. One is pickup based while the other is chassis cab. There are differences that you should look into before ever making a blanket statement about one these models without specifying.
