jimh406
Jul 23, 2014Explorer III
Chassis F450s are rated quite a bit higher than F450 pickup models or F350s if you are going chassis that would be another option as well instead of F550. They are almost at 9000 in Crew Cab form. 19.5s are also on F450s for most years which is both an advantage or disadvantage depending on what you want but would be the same compared to a F550. F450s also have a very tight turn radius, larger rear brakes and differential which is a major advantage compared to a F350 as far as I'm concerned.
