3oaks wrote:
mikakuja wrote:
As far as I am aware, the valve is only to stop anything from coming back up from the black tank. Winterizing it is not necessary as it just drains into the black tank, it does not hold water...
That's the way it should be. But with the questionable build quality in RV industry today, I don't trust that there may not be a low spot in the flush line before it gets to the black tank. When winterizing I use compressed air to clear the line.......just incase.
Yes, you need to blow out the BTF line when winterizing!! Many have found out out the hard way, that they should have.
Jerry
