riven1950 wrote:
I did try the flusher since asking the question. It acts like it is clogged or maybe the backflow valve is stuck or installed backward. When turned on water goes nowhere. It's like there's a kink in the hose. Looking in the toilet with it running there is no spraying in the tank or sounds of spray. I'll check it when I get home or a slow day on trip. I hooked up the spray wand and it did the job.there is a door right at the toilet on this tt so very convenient for the wand anyway.
Mine had a big kink in the hose about 12" from the tank causing no flow. Added about a foot of hose to make the turn easy . and works now , but still leaks under sink if to much pressure. Very seldom use it especially at dump stations as there is always someone behind me and will need dumping later anyways.
