BarneyS wrote:
curly5759 wrote:
Snip...
The black tank pipe exits the middle of the tank and is about 3 feet from the cap to the tank, with a 90* elbow, so I don't think a flush king will help, too far away to get any psi up into the tank. And, they don't sell any in town. Any suggestions?
Thanks
The Flush King does not depend on squirting the water up into the tank like the Hydro-flush does. It closes off the drain, which allows you to build water pressure up to forcefully back flush the tank no matter how far away it is from the water source or if there is a bend in the drain line leading to the tank.
The Hydro-flush will not work in that type of situation and depends on a straight shot into the tank to work. Also, once the water level in the tank has enough pressure to overcome the water coming out of the hose then it stops working and just flows down the drain. The Flush King does not have this limitation because it has a valve to close off the drain.
I would give the Flush King a try - even if you have to order it online. It might solve your problem.
Barney
The Flush King will not do what you are saying it will do. They are nothing but snake oil and a waste of money.
Bruce
