WyoTraveler
Jul 19, 2013Explorer
If all else fails you can make a wand that will always work no matter how bad the black water is clogged. I have been using a home and for about 40 years. Yup, same one. Take a 30" length 1/2" copper pipe. Install a cap on one end. Install a ball valve & hose fitting on the other end. On the end with the cap drill two holes in the side of the cap 180 degrees apart 1/4" dia. You can buy a smilar product from Walmart but it is basically worthless. There will be enough pressure to clean your tank. You will see lots posts that monitors don't work. Mine do. If they give me a bad reading I take the extra effort & use my 40 year old tank wand. The other post about filling tak and draing also helps. JMHO.
44,066 PostsLatest Activity: Jul 25, 2018
