westend
Sep 06, 2017Explorer
traveler1970 wrote:There can be differences in tank construction. Yes, you'll need to detach the drain pipe from the closet flange that your toilet connects to, hence, toilet removal. Also, the vent stack. Mine had a threaded fitting into the tank and a threaded connection to the closet flange w/pipe. The vent had a threaded connection to the tank. Some tanks have a grommet connection into the tank that the drain and vent pipe pass through. Since I relocated my toilet and vent stack, my black tank now has two new grommets in the top of the tank.
Anyone ever pull a black water tank? How does it connect to the toilet etc.? Do I have to pul the toilet first? Thanks for your input.
After I relocated these, I plugged off the original vent with a threaded pipe plug and the original toilet drain has a smaller piece of pipe and a cleanout cap. Should I have a tank clog, I can use the cleanout to access the tank's insides.
