Huntindog
Oct 09, 2017Explorer
westend wrote:I did not say the toilet flange connects directly to the tank.#3 might be the biggest headache. All the plumbing I have seen is ABS componenets. Mating that to the stainless could be a challenge
Actually, installing bulkhead fittings in a metal tank makes transition to any other plumbing material easy.
The closet flange in all the trailers I've seen have an intermediate piece of pipe between tank and flange. One would have to have a tank at floor height to have a closet flange directly on the tank.
But that there is an ABS fitting that is glued onto the tank, and the ABS pipe or flange is connected to that. IIRCC, on mine it was glued and inserted into the ABS fitting on the tank.
Not sure how else it could be done, as you are working thru the hole in the floor that the toilet uses.
Now on a new build, there could be other options.
