jamesu
Nov 03, 2019Explorer
jamesu wrote:
I recommend just using the pink stuff. I have never blown a line in my. 20 years of TT’ing. Have never had frozen pipes and my entire procedure takes about 20 minutes and approximately 1.5 containers of pink antifreeze. Run each faucet and shower (including the outside one) until it runs pink. It is not a tough process.
Also, make sure you have turned the bi-Pass valve under the kitchen sink leading into the water heater and have unscrewed the water heater plug outside the trailer and drained it before running the pink antifreeze into the system. You do not want pink anti-freeze inside the water heater.
When you de-winterize in the Spring, re-open the bi-pass valve under the sink AFTER have you have finished de-winterizing by running water until it’s not pink. Doing this keeps anti-freeze out of the empty water heater. Then keep the water running until the water heater is full.
