OleManOleCan
Nov 03, 2019Explorer
ken56 wrote:
Don't rely on just blowing out the lines. All the times I have winterized I blow the lines then put in anit freeze and there is a lot of clear water that comes out before the pink stuff does. Your trailer, your choice but be prepared to fix freeze damage.
I have Winterized several campers this way. IT WORKS.
I start off by making sure the Black and Grey water tanks are emptied...
I open all the Low Point drains and drain em. Drain the Hot water tank too.
I blow out my lines.
This time of year Walmart always has a sale on 'The Pink Stuff'.
I buy it to pump/run thru my lines until it comes out pink.
I fill the traps with Pink Stuff. I put a gallon of the Pink Stuff in the Black Tank.
I put about 4" of Pink Stuff in the Toilet bowl.
I remove my White Hose and make sure it's empty. Then I roll it up and plug both ends. (I don't want a bug to find a hose to crawl into...)
IT'S NOT OVER KILL IF IT KEEPS IT FROM HAVING FREEZE DAMAGE.
