drsteve
Nov 25, 2019Explorer
gmw photos wrote:OleManOleCan wrote:
I use a Turkey baster with a piece of rubber tubing to remove most of the water left in the water heater after it's drained.
Mine has about 3/4" of water after I drain the tank.
I get all I can get, and I have never had a problem with freezing and expansion doing damage.
After I flush all the debris that I can get out of the water heater, I use my wet shop vac with a piece of flexible plastic tubing duct taped to the vac nozzle to remove the remaining water and debris.
Not necessary. The inch or so of water remaining in the bottom of the WH will not cause any problems.
