shastagary
Aug 21, 2017Explorer
post the model number of your converter if is more than a 35 amp converter that fuse is to small. most use a self resetting circuit breaker at the battery. if your converter is trying to charge at more than 30 amp naturally it will blow that fuse. does sound like the converter could be on the way out you can get replacement power supply boards if that's it main board
