shastagary
Aug 21, 2017Explorer
ok searched and it looks like 30 amp 12v fuse is the common size used for the size wire they use going to the battery and it was said that the stock converters rarely put out that much current to the charging circuit anyway. even though yours is a 55 amp converter. i would pull out all your 12v fuses in the converter panel put a good fuse at the battery turn it on and see if it holds if it dose then start putting in fuses back in and see if any make it blow. start with the 2-40 amp reverse polarity fuses first. manual links install and manual
