wnjj
Aug 23, 2017Explorer II
Was the disconnect switch in "connected" mode when you blew that last fuse? To further narrow it down, first try with it in "disconnected" mode. Then you will know if it's the wire from the battery to the switch or from the switch to the panel, or maybe even the switch itself (if it's mounted to something grounded).
If there's a short on your battery cable, it will pull the whole 12V system down and/or blow fuses in the 120V to 12V converter so fixing problem 1 will probably fix both.
