Mello_Mike
May 15, 2014Explorer
retireclose wrote:
I'm in the process of running (2) 12v cables for a usb port and a 12v fan. I have two empty spots on the converter(15a) that I tapped into. Where should i put the 15a inline fuse, closer to the converter(source) or closer to the usb/fan port. The run is about 10 ft. and i used number 10 wire.
Any help would be appreciated.
Why are you using an inline fuse if you have two open slots on your converter fuse panel? I would use one of the open slots for your fuse and wire connection.
44,068 PostsLatest Activity: Jun 17, 2026
