hedge
May 27, 2014Explorer
I got mine installed on sunday. I mounted the '360' plate in the kitchen wall. There was an AC plug there already so I was hoping I could fish my wires through the same hole... but no such luck. I had to drill my own hole from the upper gun cabinet down into the undersink area. Wow was I nervous drilling that hole... I had visions of it coming out through the outside of the camper. Things like that happen to me.
I then decided I couldn't make the big square hole because of the framing for the cabinet behind the plug so I just drilled the holes for the actual plugs. This worked pretty well other than I also had to drill countersink holes so that the plate would sit flush against the wall. Here's a shot showing the holes drilled.
This is a shot with the plate mounted. It looks a bit crooked but it's actually the AC plug that's installed crooked, I'll have to fix that. It doesn't look as bad in reality.
I also installed a plug beside the bed, I couldn't see anywhere clever to put it so I just top mounted it. It was handy because I could run the wire inside the same cabinet.
To feed it I tapped into an unused pigtail wire feed off of my converter. The ground went to the grounding block.
I like the plugs but I'll probably take them apart to disable the LED, especially the bedside one, I think the light will drive me nuts.
I have a couple more of the small plugs and I'll probably run a line behind the fridge and the wardrobe over to my wife's side of the bed. Somehow I ended up ordering 2 of the 360 plates, not sure where the other one's going to go.
44,069 PostsLatest Activity: Jul 06, 2026
