D_E_Bishop
May 29, 2014Explorer
retireclose wrote:
I'm in the process of running (2) 12v cables for a usb port and a 12v fan. I have two empty spots on the converter(15a) that I tapped into. Where should i put the 15a inline fuse, closer to the converter(source) or closer to the usb/fan port. The run is about 10 ft. and i used number 10 wire.
Any help would be appreciated.
I'm kind of as a loss as to why you used #10 wire for your run to a USB port and a fan. A USB port normally supplies no more than 2.1 amps and most 12 volt fans only draw 3 or at most 5 amps.
The voltage drop for 5.5 amps in a ten foot run of #14 wire is only .285 volts. For #10 it is .113 volts. Seems to be a bit of overkill using #10 or have I missed something.
44,069 PostsLatest Activity: Jul 06, 2026
