wgriswold
May 19, 2018Explorer
Bolts Failing on Equalizer Hitch
I have an Equalizer Hitch with 1400 lb bars. Today I replaced the third pair of bolts and nuts that attach the head to the shank They are grade 8, 3/4" in diameter and 5" long. The threads failed on the bolt and the nut had some damage but not as bad. The first time I had to cut off the failed bolt. This time I was able to get it off with lots of WD40.
The directions say to torque these bolts to 420 ft-lbs (see edit) and I found a table that confirms this value. I do this by putting a socket and breaker bar on the nut and then a pipe over the breaker bar. I stand at 2 feet on the pipe and since I weigh 208 lbs that should be about the right torque.
So, why are my bolts failing? Has anyone else had this problem?
Edit: The torque for these bolts is 320 Ft-lbs. I confused the torque for the ball with the torque for the bolts.
