Camper_G
Jan 15, 2017Explorer
lawrosa wrote:Camper G wrote:
I nearly bought this rig at the rv show in hershey, pa this year. Great price at the show. I like the 261bh, it's comparable to the jayco jay flight 26bh, but the jay flight 26bh has a plywood roof and a roof ladder, bigger fresh water tank capacity, black tank flush and other options.
The coachman has an osb roof and i didn't care for that. Inside it's very nice though. We really did like the coachman 261bh.
I was sure the jayco is osb too.. I looked at that unit There seem to be more quality issues with jayco from my readings..
The coachmen has a bigger fresh water tank @ 46 gallon. Jayco 42 gallon.
Option? The coachmen has the free customer value package.
1 13,500 BTU DUCTED A/C
2 POWER AWNING WITH LED
LIGHT
3 6 GALLON G/E DSI WATER
HEATER
4 SKYLIGHT ABOVE
TUB/SHOWER
5 STAB JACKS (4)
6 2 - 20 LB LP BOTTLES SHOWN
WITH OPTIONAL BOTTLE COVER
7 UNDER MOUNT DUAL BASIN
DEEP KITCHEN SINK
8 RANGE HOOD WITH LIGHT
9 AM/FM RADIO WITH CD
AND DVD PLAYER
10 DIGITAL MICROWAVE
11 3 BURNER RANGE IPO 3
BURNER COOKTOP
12 OUTSIDE MARINE GRADE
SPEAKERS (2)
13 FRONT DIAMOND PLATE
14 LED INTERIOR LIGHTING
15 SPARE TIRE AND COVER
16 REAR VISION CAMERA PREP
18 PLEATED NIGHT SHADES IN LIVING ROOM
17 SPORT WHEEL PACKAGE
It is 7000 or 7500 GVWR though and over 29' long and that is a lot of trailer for a half ton truck. That's one reason i held off on the purchase until i got a 3/4 ton truck.
Its 29 ft. same as the jayco. They are also both 7000 lbs loaded max..
And they both come in at 4800 lbs dry..
My 15 Silverado would have pulled that coachman, but with all the gear, passengers and tongue weight i would have been at or over my payload limit.
I don't know what year your half ton is, but I'd check your weights when you have time to see where your at weight wise.
Dont know what truck you have. Mine is an 06 silverado as in my sig. 6900 lb gvw. I took it to the scales and with myself 215 lbs and a full tank of fuel , 34 gallons, I have a remainning payload of 1425 lbs.
Both TW's are 540..
Truck says it can tow 7500 lbs. If I get 1000 lbs in that camper id be suprised.Propane is included in the weights so the only additional items would be batterys for the dry weights.
Congrats on your purchase. It's a really nice rig.
Thank you.
Watch these videos.
https://www.youtube.com/watch?v=cfP6xDnVprQ
https://www.youtube.com/watch?v=jXMJrRQ3SVk
Yes sir, I've seen both of those videos. Unfortunately, most if not all RVs in this price range are built the same way.
You are comparing the jayco jay flight 261slx. That model has the osb roof and smaller fresh water tank.
The jay flight 26BH is the nicer model with the roof ladder and plywood roof, black tank flush, 80 gallon of fresh water capacity, etc.
I suppose the more fair comparison is the jayco 261slx to your coachman. They are similarly priced. The jay flight 26bh is about 4k more. Both jaycos had a much larger rear storage area under the bunk beds, the jayflight 26bh also has a small refrigerator back there which is really nice.
Given a choice between the coachman and 261slx jayco I'd have gone with the coachman also. It's a lot of trailer for the money.
I had a 15 Silverado 1500, 5.3/3.42 gears, 1704 payload, 9100 lb tow rating. So My old truck had more capability than what yours does.
The trouble with half ton trucks is that you'll likely run out of payload way before you get anywhere close to your tow rating.
So in your case, if you take the tongue weight off what you have left after your weight is taken off, your already under 1,000 lb of payload left.
How much does your hitch itself weigh? How many passengers will you have with you? What do they weigh? What about camping gear, firewood, a tool box, floor jack, etc?
The jayco 261slxv is 6500 gross, so 500 lbs lighter than your coachman, at least in rated capacity.
I think you may be surprised at what payload you have left when all is said and done.
Typical tongue weights are 13% of trailer weight, if i recall correctly, so if we use 7000, since that's a more realistic fugure than the dry weight it's, that's 910 lbs. If we go 10%, that's 700 lbs. Either way, i think your light on your tongue weight estimate.
Will your truck pull it? I'm sure it will, but a long trip to Disney or myrtle beach is asking a lot of a now 11yr old truck, loaded to near if not over it's capacity.
I suspect you'll want more truck after a few trips, but maybe not. If your within all your limits, loaded weights, then that's great. What does the yellow sticker on the driver's side door jamb say your maximum weight of passengers and cargo is? I'm not sure how your coming up with 1425 lb of payload remaining, but that yellow sticker is where i got the spec for my Chevy. Perhaps that is the yellow sticker payload limit. That might be right for a 2006 model year Chevy half ton.
I'd check to be sure though if it was me. Again, just my opinion.
It's a real nice rig. I still may consider one when we get serious about looking again in the next few years.
