schlep1967 wrote:
Some lugs, for some stupid reason, have a thin cover of metal over them that is chromed. If this is the case you should be able to cut and pry that off using a dremal tool and pliers/screwdriver. Once that is off the lug underneath will be actual steel and a smaller socket should fit it.
schlep1967 you where right I removed the thin metal cover that was over the nut and re-tight the nuts.( Before going on the trip ) Also I would like to thank everyone that helped out. I apologize for not getting back to you sooner I do not get on social media when I go camping, unless I have an emergency issue.
Respectfully
Kennedy
