The fuse block is under the dash to the left of the brake peddle. I decided to take out the fuse and test the hot side and I still done get power unless i turn on the key. So to me it says there is an issue from the panel back to the battery somewhere. The fuse for the brakes is the bottom most fuse on the left. That is the one labeled brakes. I am wondering if the fuse is miss labeled, but this is the fuse i get continuity to off the orange wire going to the brake light switch. If you have any more input, please let me know
