MFL
Jun 26, 2020Nomad II
Six years is a long time to sit in the elements. Best option for brakes, would be to remove the hubs, clean the rust/corrosion from the hub braking surface area, and make sure the shoe pivot points are free, and lubed.
After using the trailer, using the brakes, it is easy to put one wheel at a time up to properly adjust each brake. This being done, the brakes should work as good as they did years ago.
Jerry
Jerry
44,068 PostsLatest Activity: Jun 21, 2026
