Community Alumni's avatar
Community Alumni
Feb 26, 2015
Brake Myths
Here's an article I ran across this morning dispelling a few popular brake myths and common beliefs. The author does a pretty good job explaining how things work in the real world.
Link
  • Wow, your Suburban looks exactly like the front rotors on my Vette, (two piece racing rotors) after it was tracked with track pads. My main challenge is when daily driving it - the pads never get up to temperature, and the Stoptechs are too mild at low temp.
    Your Silverado has a nice transfer layer, something I just can't seem to maintain with these Stoptech pads (with both cars). Never had a problem before, with various semi-metallics. I blame the "para-aramid" material Stop tech uses, are you familiar with this material at all?
    My experience thus far with aftermarket pads: it's easy to design a pad for high bite at high temp, or high bite low temp, but almost never BOTH. The OEM pads on both my Intrepid (police package) and Z06 excelled at BOTH. They can easily ABS sticky summer tires at reasonable speeds, and still be fade proof on any mountain road. Downside? Both near $300 for a set of front pads :(
    For the Intrepid, I just bought a set of NAO pads from Raybestos, which promises very good low temp bite (FF pad), but relatively poor at high temp (like all NAO pads). That's perfect for daily driving. I'm hoping this will be aggressive enough to keep a nice clean transfer layer on my rotors.
  • RoyJ
    Am currently hating the proto-type set on my Odyssey. Test brake stuff for buddy
    all the time and this set the worst he's ever designed
    Supposed to be all-round with higher temp attributes
    Yes, but the low end binders out-gas too much and have shuddering every time and
    have to scrub off the deposits each day out on the freeway
    Yes, has both high temp and low temp braking. Better at the high end..as usual
    My TV (Suburban)...cryogenic slotted rotors and Praise Dyno pads has heat
    checked the cryo rotors...ripped the surface apart when hot and braking HARD
    cryorotor heatchecked slottedrotor
    This is my Silverado with NAPA HD rotors and Praise Dyno pads. Notice the
    even coating from out-gassing...some would call that 'glazed' but
    since even thickness...perfect for me
    silveradorotor outgas out-gas bedding
    Have to re-bed them all every once in a while because have to brake VERY hard
    to get them HOT and out-gassing...then to have to stop and bake on a high spot
    {edit}...forgot to touch on the OP's link arthur...about his thinking
    that slots scrap of glazing or some such off of the pads...if true...then
    pads would NOT last long being scraped down with each passing
  • wintersun wrote:
    To use the comments of someone who has years of experience with racing brakes and apply this to all manufactured vehicles for sale to the general public makes no sense at all. The care and expenditures involved are vastly different for a passenger car and a race car where the engine alone costs more than whole passenger car and may only last for a single race (hopefully it does).
    Only difference between a racecar and street car is the desired temperature range and the mu at that temperature range.
    Otherwise, as BenK mentioned, physics is physics, bet it a Camry, LeMans prototype, or loaded logging truck downhill...
  • BenK wrote:
    That guys image of a high spot is from the StopTech site and still amazes me
    that so many don't believe that a 0.0001" high spot can cause the steering wheel
    to jidder as if warped rotor
    Speaking of StopTech, my experience so far is the worst case of pad deposit compared to just about everything else.
    I'm using their "street performance" pads, which has a nice high temp behavior - maintains F friction rating to 1100 deg. But at low temps, they're just not aggressive enough to abrade away the deposits.
    This happens on both my daily driver (Intrepid), and fun car (Z06). Takes repeated hard braking every week or so, and it comes back in days :( I'm so paranoid that after every stop I'm in neutral with the handbrake on to avoid hot pad on rotor.
    Gotta say their high temp bite is very nice though, and just about un-fadeable on the mountain road.
  • The laws of physics apply to everyone...to the ultra high end...like racing...down to the little old lady who only drives a few miles a week
    High end would not 've a good setup for that little old lady...nor would her level work well for a racer...but both their stuff all are based in SAME laws of physics
    The issue is in taking attributes out of context
  • To use the comments of someone who has years of experience with racing brakes and apply this to all manufactured vehicles for sale to the general public makes no sense at all. The care and expenditures involved are vastly different for a passenger car and a race car where the engine alone costs more than whole passenger car and may only last for a single race (hopefully it does).
  • That author also has some that should be debunked...
    As long as there are binders in friction material...there will be out gassing.
    That out gassing is a desired 'feature' of friction material, but it needs to be
    done correctly. As friction material on friction material is the goal....but if
    you stop while the friction material is out gassing...it will bake a high spot
    and why some will say no such thing as a warped rotor...just high spots that cause
    the jitter when the pads comes across those high spots
    Finally...folks (some) are seeing the issue with drilled (cast in is just okay)
    Not many know that drilling (even cast in) holes removes mass and mass is one
    key component in heat rejection management
    Slots do aid in managing out gassing and is not really to wipe the surface of
    the friction material.
    That 'glaze' is the out gassed material redepositing on the friction material
    that out gassed and on the cast iron.
    DO NOT
    use sandpaper
    with ALU Oxide to remove glaze...it will leave particles that will then sand paper
    your friction material. Use EMERY CLOTH or Scotch Bright (2nd best)
  • Woa, you mean something that looks cool isn't always the best choice? ;)
