agesilaus wrote:
Well they don't seem to have fixed the problem over the years, my 2012 F350 6.7 4WD is on it's 3 set of pads and calipers.
I was going to say that a common denominator for the other 2 guys is they live in the salt belt.
Your issue cannot be the same as theirs, or are you driving your truck in the ocean down there in the FLA?
What is the issue with yours? Brand new calipers freeze up every 3 years?
This is not a typical mfg issue. There are literally millions of Superdutys running around without brake issues. And every other vehicle
Sometimes it helps to determine the cause, or your condemned to repeating the past.
