walker111
Nov 04, 2016Explorer
Brakes F350
May be a difficult one to answer but here goes, My 2012 350 diesel just turned 80,000 km. Out of this I think about 40k was towing a 8k fiver for three years and this year a 15 k toyhauler. Thinking ...
Golden_HVAC wrote:
I would also highly recommend going to the Ford dealer, pick up a quart of the class A motorhome rated brake fluid. It has the highest possible "Wet boiling point" of all brake fluids, and replace the brake fluid. After about 5 or 6 years, the brake fluid has the opportunity to absorb a lot of moisture, and should be changed. The old brake fluid can reach 700F and some moisture in the fluid can change to steam bubbles, that can compress, giving a "Spongy" feel to the brakes. Changing the fluid every 5-7 years will prevent this.
Good luck!
Fred.
