If you have an air compressor, then Harbor Freight has a kit for brake bleeding. It uses the compressed air to create a vacuum, probably with the venturi effect. It has a reservoir bottle and you can suck your spent brake fluid into that from the wheel cylinders.
I generally won't try any HF tools that aren't solid one or two piece metal. Wrenches and such. But this kit got some good recommendations and I tried it and it works. They also have another kit with a hand pumped vacuum system, I have my doubts about that one.
