Espnart's avatar
Espnart
Bubbled Fiberglas
We just brought a 2012 Viewfinder 19FK from an elevation of 4500 feet to 8500 feet, then back to 5500 feet, in high southwest temperatures. This was over a two-day period. When home, I found a round area of about 1.5 feet where the Fiberglas had bubbled. It is not crazed or cracked. I am concerned that it may not deflate and that the stress on the fIberglas will result in a leaky break. Any words of advice or experiences like this to share? Thanks much.
  • WNYBob wrote:
    Sorry but you just lost thousands in resale value!
    Delamin8is most of caused by moisture in the Luan behind the fiberglas! Maybe a minor leak around the window.
    I will not buy an RV with WOOD backed fiberglas!
    Kind of severely limits your choices then, in as much as 90% of them today are vacuum bonded fiberglass (Filon) over wood substrate.
    I'ts delamination for sure probably cause by water intrusion from a leaking window seal. Seals and caulk need to be checked and maintained a couple times a year, something very few owners do until bad things start happening. The they 'reactive' instead of being pro active.
  • Sorry but you just lost thousands in resale value!
  • Sounds like delamination. The trip probably had nothing to do with it, other than causing it to show up now. Likely road vibration and weakened glue just let go.
  • Driver side, about a foot from a window, at about 4 o’clock...
