westend
Nov 01, 2014Explorer
MorMJS,
Sewer flies resemble fruit flies. Were you recently connected to sewer hookups and had the tank valve open? The only cure I've read about is to spray bug killer into the black tank. I've never had this, or any other bug issue and not so sure I'd use gobs of bug killer into my RV. A mechanical cure with fans and open windows might eliminate most problems. Then again, it will be subzero here in a little bit and there are very few pests that make it through that.
44,068 PostsLatest Activity: Jun 20, 2026
