ShinerBock
Jul 25, 2017Explorer
JIMNLIN wrote:
You may already be aware of the problem some owners had with the F150HD 3000+ lb advertized payloads and adding all 3000 lb in the bed of the F150HD overload the trucks 4800 RAWR.
The 4800 RAWR is good for up to maybe 2400-2500 lbs in the bed depending on the trucks actual scaled axle weights.
Probably one reason Ford dropped the old 8200 GVWR numbers back to 7850 GVWR.
One F150 owner came up with a 6800 GVWR and small 3800 RAWR with max tow package...so choose the bigger GVWR packages with the bigger 4550-4800 RAWR numbers.
Good luck
The only F150HD's that have a base payload of 3,000 lbs are the regular cab trucks and according to Ford fleet have a rear base weight of a little under 1,900 lbs. That would give you about 2,900 lbs before going over the rear GAWR. The Subercab F150HD's have a base payload of around 2,700 and the crew cabs are around 2,600 lbs. However, even on the heaviest crew cab 4x4 configuration, you can add a little over 2,700 lbs to the rear before going over the GAWR which is more than its 2,600 lb payload rating. These are of course base ratings and will change with options.
