TexBohunk
Jul 25, 2017Explorer
mooky stinks wrote:
At the scale with my current truck and trailer I'm @ 39XX with a RAWR of 4300lbs, so 4800lbs would be a nice cushion. There's zero chance of us getting a bigger TT. Next RV will be a decent size 5er and 3/4 or 1 ton. I'm a little disappointed that it has to be an 8ft box or CC. They sure don't give the CC's away.:E Either does the General.;) Thanks everyone for the heads up on the rear axle and configurations.
You mentioned upgrading to a 5er on your next RV, have you considered trying to get the 3/4 or 1 ton now. A gasser 3/4 can be had for the same or less than a 1/2 ton. You could have the payload you need and more options on cab/bed configuration. Just depends on how big you want to go later. Just my 2 cents, good luck on you decision.
